Clio Tyres
6 Feb 2008
Just a quick question got a 2003 Clio 1.2 dynamique and just need 2 front tyres sizes are 185/55/15
Was wondering what you more knowledgeable people would recommend? And is there any sites which I should use that maybe cheaper?
Looking at the 185/55R15 82H Goodyear Efficientgrip ~£64 a corner fitted if I can remember rightly.
Thanks
Continental contiprimium contact 2s is what we use on our clip in that size. Find them excellent. Price is about the same as the goodyears you mentioned.
195/50/15 are much cheaper. The gfs Clio needs 4 new tyres soon so will be looking at this size rather than 185/55/15. Can get decent ones for £60 fitted on event tyres.
Something with low rolling resistance would be good.
195/50R15 82H PIRELLI CINTURATO P1
£69.00
Per Tyre Fully Inclusive
4 tyres£69.00 each
3 tyres£71.50 each
2 tyres£71.50 each
1 tyre£81.50
These are rated as C for rolling resistance, quiet at 67db and A in wet.
Everything else is rated F for rolling resistance
£69.00
4 tyres£69.00 each
3 tyres£71.50 each
2 tyres£71.50 each
1 tyre£81.50
I pay less than that for the continentals, fitted, and in the correct size. :)
