A few weeks ago I built a new rig which included a H100. Soon after the install I was hearing this grinding sound, I contacted OcUK and they started an RMA, the sound did actually stop the day after so I just left it.
About a week ago it started again so today I called up and will continue the RMA and get a replacement as this particular sound is common with the Hydro series coolers.
I was running a moderate 4.2GHz overclock on my 3770k with load temps reaching 68c and Idle temps of 36c which I didn't feel was that bad. After removing the H100 to return it I noticed there was a patch in the center of the H100 thermal paste which wasn't actually in contact with the CPU.
I've installed the stock Intel cooler for now until my replacement arrives but I'm really quite concerned about this patch of thermal paste which is still intact as my idle temps are exactly the same now as they were with the H100.
Here is a pic of the CPU block and the paste. Ignore the finger print, I had just done that
http://imageshack.us/a/img109/9558/10004771.jpg
As far as I could tell the CPU block was fixed securely so I'm not sure how this happened.
Thanks
Thanks
The wedge shaped bit doesn't look like it ever contacted CPU.
