Will Overcloking kill my lifespan?
27 Jul 2012
Should I overclock my Sapphire Dual Bios HD 6950, or my AMD Phenom II X4 965 to get better performance, but with not much difference in life span?
I want them both to last for roughly a long time 2-3 years
As long as you keep them cool overclocking does not significantly reduce the life span of components.
Matt
I've had my 1.28V Q6600 @ 3.2GHz 1.34V for 4 years and it's still going. I think as long as you keep the voltage and temps down it will still last a long time. 3 years would be under the most extreme conditions, like passively cooled, dust covered, in a dell desktop case with 1 fan or something. :p
Matt
this^^^^ keeping the temps and voltages within safe ranges are the most important.
my kids pc has a q6600 overclocked to 3.4ghz that has been going strong for 4 years+
I wouldn't imagine so, the important thing is to eat well and have plenty of exercise, then you'll have nothing to worry about :)
ROFL ROFL
As for your CPU's lifespan; overclocking does not reduce it's lifespan as long as you don't go extreme. Keep it well below max temps and it will last a long time.I have a Athlon X4 620 @ 3.55GHz and i7 920 @ 3.5GHz that have been running for a couple of years now no problem.
Have a 10 year old Athlon XP 2400+ that's been running pretty constantly for about 7 with a bit of sketchy cooling and a 20% overclock. It's now been retired from OC duty and instead powers a HTPC. It undervolts well for the core type even after all these years. Who cares if a chip lasts for 10 years instead of 15? :p
Can anybody tell me the safe voltages/overclocks for an AMD Phenom II X4 965, and a HD Sapphire 6950 w/Dual Bios?
I want to know the safe overclocks for them, so should I just google it or read the threads? :P
At the very least 3.7GHz and 1.4V or less (980BE speed).
Just don't exceed 1.55V and you'll be fine. Also any settings above 55C core temperature will most likely be unstable, so try to keep it lower than that.
That's not really a good thing to say.. Couldn't I blow up the ****ing CPU? lol :D
It's the truth.. and yes it is possible you damage it. But if you don't overvolt it the likelihood of damaging it is much less. Every CPU overclocks different. There are no magic pill of settings that will give you your 4.0GHz oc. ;)
I won't ruin the CPU if you don;t go too far. It's a bit of a theory rather than something that has been measured and proven - after all, with the current gen of cpu's, the manufacturing processes engaged have not been around long enough to be able to measure degradation over time.
It is believed that as the voltage approaches and exceeds the maximum permissible voltage for that chip, then the chip's construct begins to degrade at an atomic level. I've not seen any evidence of this on my rigs, but it's quite widely reported that if you increase voltages, say for Sandy bridge, above 1.5v for any period of time, then previous lower overclocks that were achievable, would no longer be stable at the voltages previously attained - more being required.
My advise is don't go too extreme if you require the kit to operate for long periods of time, for a long period of time (ie 24/7). This is kind bore-out, at least anecdotally by the server range of chips, ie the Opterons and Xeons. Both ranges have lower V ranges than their desktop counterparts, and overclocking is NOT supported out of the box. Maybe I read into that too much though...
At the end of the day, it's about risk. 65nm chips contain much more silicon per transistor than 43nm, 32nm or 22nm ones.
It stands to reason that as well as requiring higher voltages to operate, they are likely to be more durable as to degrade requires more material to physically degrade.
CPU degradation is very widely discussed subject, but is one that I've not seen any solid articles on - but lots of reported instances that hint that it has happened.
Every CPU contains microscopic differences, and this is only really discussed on a batch level. You can with a lot of searching find out peoples experiences with a particular batch of processors, however, you will also have to take into consideration the other kit that they operate (motherboard and PSU will be absolutely key) as these will also affect the power supply to the chip.
