- 14 Dec 2011
yes dual water cooling loops, might as well keep the cpu's and gpu's separate, eh.
Ahh OCuK, now I know why I hesitated joining, the search continues for a PC forum with mature members.![]()
you said there was no budget. a blank cheque is what we saw and we went for it..
A blank cheque is every Computer enthisiasts dream!
i think everyone went into. if i won the lottery what pc would i buy right now?! mode.
you want a serious build. give us a budget, and what it will be used for. how many monitors? os? keyboard and mouse?
This will be used by three 24" monitors for racing games/FPS.
COOLERMASTER COSMOS 2 ULTRA TOWER
Overclocked Intel® Six Core i7-3930K Overclocked to 4.6GHz
ASUS® RAMPAGE IV EXTREME: INTEL X79, SOCKET 2011, R.O.G
x2 GTX 690's
16GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz
240GB INTEL® 520 SERIES SSD
1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE
1TB WD CAVIAR GREEN WD10EARX, SATA 6 Gb/s, 64MB CACHE
CORSAIR 1200W PRO SERIES™ GOLD AX1200i DIGITAL MODULAR PSU
COOLIT ECO II C240 DUAL RAD LIQUID CPU COOLER
Creative Sound Blaster Recon3D Fatal1ty Champion
So, anything you would change if money was no option?
Why two different variants of storage drives? Why wouldn't you have two of the same?
Your looking at building a PC with dual GTX 690's and a six core cpu overclocked to 4.6ghz and running three monitorsThe green uses less power and is more of a storage drive than the other.
And you worry about saving a few watts of power on one harddrive....
I really no understand the way some people think..![]()
There is no budget in reality, but making builds that are 11k+ adding in t-shirts/mugs is not what I want....
The current build I had in mind was around 4.2K.
I will be playing sim games and FPS games on 3 24" monitors, so if anyone has a build for something like that I would appreciate it.
ok apologys for the mugs and energy drinks those were just for a laugh......apprently not
and been as you said there was no budget and basically handed a blank cheque we tried to make the most overkill pc possible as there were no constraints based on what you had said, so if you are not willing to spend 11k and deem this "immature" then set a budget, so now that you have said 4.2k is what you had in mind then a pc can be worked for that region
here is a build based on your previous post, you havent stated wether you already have the monitors and wether you need keyboard/mouse/os so i havent added those. also the majority of the sensible priced raid cards are only pre order, so the only one in stock is the £660 one.... but here is the base system, you can change the case i have only provided a good example (800d is amazing case btw see videos around the web) you also add in the monitors and keyboard and mouse should you need them, but this provides you with a system to give you an idea of whats out there, you can swap to preferred brands should you wish also
As I am not building it myself I can't select some of the parts from your post, I used this http://www.overclockers.co.uk/productlist.php?groupid=43&catid=2385&subid=1951 to build mine, would you be able to build one with that link that's better than the one I posted?
