Am I the only one who always preferred the pre-facelift coupes? Especially the wheels.
Yes
The pre facelift E46 coupe is looking a bit tired now.The later MV2's never looked as good to me.
lies.Am I the only one who always preferred the pre-facelift coupes? Especially the wheels.
lies.[TW]Fox;23011580 said:MV2's are horrendous wheels.
[TW]Fox;23010151 said:You don't. You just remove the old bulb holders and slide the new ones in. No disassembly required.
Doesn't the 330Ci have those as standard irrespective of whether it has Xenons or not?
325i on the other hand doesn't have it.
Indeed. Sorry![TW]Fox;23012118 said:Loads of M54's came with a 6 speed box so I've no idea what mjt is on about saying none of them ever did - there was a wide range of models available with a 6 speed box - facelift E46 Coupe, Saloons and Tourings post 03/2003, Z4, E60 5 Series, etc.
Infact IIRC the only M54 fitted car to never gain a 6 speed box was the Z3 and the E39.
The final stage resistor for the heater fan unit sometimes dies and doesn't regulate the fan speed properly. Cheap part...not so nice a job to replace!
I'd have to diagree with this. I replaced the FSR on mine and with the right tools it takes about 45 minutes. Not the worst job by far, and I'm not at all handy with the spanners.
How is fuel economy with the 6-speed? Is it just shorter gearing all round or lower rev's at motorway speeds in 6th?
This site is quite useful for a comparison:
http://www.bokchoys.com/differential/e46_gear_ratio_calculator.htm
