Heads up, atiumdva.dll was deleted by my av, could be handy to exclude it or check in case you missed it getting quarantined.
I still think there is more power waiting to be unleashed, hopefully the longer it takes the 8's to release, the more Amd will get out of it...
...although they should try and get rid of the 'humbug' vertical stripe screen of doom.
It's not constant, it can go a week or so 24/7, totally fine, then 3 or 4 times in an hour, when my boys playing Minecraft(kids crack cocaine
, be warned if your kid asks for it anyone) and watching youtube Minecraft vids.
Come to think of it, it hasn't done it on the GHz bios, yet anyway.
@Matt,
NP, pity it didn't work, but I didn't install the driver until I flicked to the GHz bios-whether that makes a difference, at least you got something sorted.
Must be a software conflict somewhere as  the cards are identical and there's not much difference between our systems.
@JD,
go for it, and the Asus monitor looks the part, reading that review, it looks like the Nvidia used the same format as Samsung with lightboost, so I guess I'm getting similar results as lightboost, which must explain the good 3D.
@Marine,
I'l start a thread when I get some free time, been so busy the last week or so, not had much time to do anything recently.
