Permabanned
- 28 Nov 2003
- Shropshire
We have a meter and main fuse / breaker box on an external wall of the bungalow. Presumably the cables go up the cavity to the roof space and then across and down to a distribution panel in the utility room. I want to run a high amperage cable from the meter box, same as I have done to the workshop under the concrete with armoured cable, but this time up into the roof space and across the house. I guess this is common for high wattage showers people seem to favour these days ---- 6kW plus. What's the accepted way of getting cables into and out of the cavity to the meter box? I don't believe the cable to the distribution panel will take the current I need to draw. Thanks.
