- 1 Oct 2003
- Huddersfield
You don't need to rebleed if you shorten the hose, also why are you using 2 fingers to brake?
Nope, you need different shifters without the gear indicator. I ran into the exact same issue with my girlfriends bike a couple of weeks ago.Got my brakes fitted tonight in the front room much to the dismay of the wife and cat
Couple of things I hope you guys can advise on first easy one the front hose is too long is it worth shortening it as this will require replacing all fluid and re bleeding.
Secondly with these brakes the shifters feel like they don't belong.
At present (see pic 2) I have the brake leavers right up against my grips which is not quite the right position. They need to be further away for my first two fingers to sit comfortably on the lever. This puts the shifter out of reach. I have tried putting the shifter the other side of the lever but it interrupts use.
Am I in need of new more compatible levers than these shimano deore items? Or am i being a noob positioning them?
Yes its a single pivot, but then so is the Session 9, Wilson split pivot etc.
So you reckon a bike should be priced by the amount of over complicated linkages it has? (Or moar chainstays perhaps and higher profile bushy eyebrowed riders straddling it? )
Revolutionary would not be the word that I'd use...though unsure which suits best.
Whatever word describes suspension that never over or under reacts and offers incredible amounts of grip...and acccelerates when things get gnarly.
Had I had a chance to ride a Morewood maybe my thoughts would be different.
awesome looking trails RX..
Excellent shots Cow...When is the video released?
No hotlinking
I usually use one i was merely trying to give an indication of the distance i feel the lever needs to be away from the grip/were i have my hands. Can i not just remove the window things on my shifters?
How would i shorten the hose without removing everything having it cut to size then putting it all back together?
didnt know this, will try doing mind tonight. Presume i'll just need the bits from a bleed kit?
You should just be able to undo the hose, remove the fittings, cut the hose to length and refit. You will only need to bleed if you for some reason lose any fluid. Just be gentle with the hose and none will leak out, except from the bit of hose you remove.
