Gigabit switches, buy the cheapest or is there a difference
27 Oct 2005
Netherlands
Hello,
I need one or 2 gigabit switches to get enough cabled LAN connections at home everywhere I want. I remember reading something a while ago that there is barely ANY difference between switches, even the el cheapo ones were 910 mbit at worst...
Is this true? Should I just go out and buy any el cheapo unmanaged 5 port gigabit switch for 10-15 and will it not lag the network down ?
Depends on what goes on in your network.....
Are you gaming all over the house?
If it is just general web usage and media streaming then I would imagine any old GB switch would do.
Yeah, you certainly don't need managed ones for a home network.
What i did for mine was stick a 24-port 3com gigabit switch in the loft and then cabled down into each room, terminating in a wallplate that housed 1 x RJ-45 and 1 x coax (for tv distribution too).
But, i use those tplink ones at work for when our desks don't have enough ports in the floor. They work fine. I certainly recommend them for home use.
A lot on here don't have issues with the cheap switches, but personally I spent a bit more and went for the HP Procurve desktop switch.
I've got a Netgear GS105UK Gigabit and a HP 1410-16G 16 Port Gigabit Switch in my house and can't fault either. Super fast transfer speeds between server and pc's etc. Very very good.
