this okay before buy ?
It is ok.
I should have asked in the previous thread, you do have the socket 1156 (same as 1155) mounting for the Fenrir cooler?
Looks fine to me. Only reason I would change the RAM is if you were looking to match the colour scheme of the board, but there is nothing wrong with the stuff you have chosen. Looks like a solid budget build :)
The board+CPU you are buying are socket1155.
When I had my Titan Fenrir, it came with the socket 1156 mounts sello-taped to the rear of the box (it was added on as early versions never had socket 1156 support)
Socket 1156 and 1155 are the same, so if you have these fittings, then you are ok.
