Ive had a google of this, but nothing seems to come up at my relevant point, nor has the issue(s) seem to be resolved.
The spoiler is embedded within the problem, so have hidden it just incase there are a few that havent bought the game yet.
I would try and re-install the game, but would prefer if there are any other possible fixes before doing that.
GPU/ CPU isnt a problem in terms of both stability and temps, cpu maxes at 50c and gpu 55c, both on very mild and stable OC's.
Thanks
Ive just set up the new beacon to get back to Sanctuary. Initially when I tried doing it, there was still a few loaders left and I was on low HP, so thought it glitched slightly and I got killed as I tried to use the fast travel.
I then restarted the game and the same crash happens with no loaders about.
I can walk around fine, go do other stuff, but to progress, I need to get to sanctuary.
Thanks
