Windows 8 who's buying/upgrading
edit tht.
Had to uninstall google chrome again.
Just kept freezing my pc would change tabs but wouldn't load pages or exit from chrome.
uninstalled and everythings perfect again
How long did peoples upgrades take?
Mines taken an age and its still going. Its now rebooted a few times and its now stuck on the boot screen with the spinning dots. Been like that for 15 mins
upgrade wet smooth enough iI think , tool a while though.
Daft question, I set the colour to blur originally, then on my login changed it to grey/green. But when I boot up the that screen is still blue, how do I change that?
Balls rebooted manually and it got past hat screen then I get he message saying that the install was not successful and its restoring windows 7 .
Well hat went well I. Think not
Attempt part 2..........
Maybe, several of us have upgraded from PR with no issue. However if you have no valid license to upgrade, then it's not really legit.
Ahh well it worked anyway so now it's legit. I have it legit on my laptop anyway :) upgraded clean ssd install £14.99
Well attempt #2 seems to have got stuck again at the last bit :( looks like m going to have t try a full install.
I just got email confirmed to have my money back as I ain't happy with Windows 8 Pro upgrade (it been freeze 11 times) revert back to windows 7. Microsoft is lies as Steve say all hardwares been tested and will work, rubbish, he is lying.
Dear Mr. *******,
We would like to inform you that the refund for your order *******, was processed on 26.10.2012 and you will receive the money back into your account within the next 5 working days.
Kindly note that due to billing cycles, the refund may not appear on the same credit card statement as the original charge.
Thank you for using our services and please feel free to contact us if you should have any further questions. We are happy to help.
Kind Regards,
Microsoft
cant get my windows.old to delete suggestions ?
You can do it with windows disk cleanup, just right click C: drive and go to properties, then click the clean up system files button, should see old windows installation... just check the box and clean up/remove.
