- 16 Nov 2003
- Thessaloniki
did they fixed the core parking bug win7 had?
There's lots I'm still confused about as they've moved a lot and I'm used to finding everything from the start menu
Good start, upgraded my laptop from Windows 7 (after using Clonezilla to image it first I might add) and getting introduced to Windows 8...as a blue screen, well light blue sad smiley face Blue Screen.
So yeh, not all that impressed at the moment.![]()
And i want to pin the power off option somewhere to save me all the clicks to get to that.
The only thing is when you run an app there doesnt seem to be a quit option unless you move the mouse over to the left , get the little thumbnail and then close from there. But other than that, its pretty good. Well worth the £25 anyway.
And i want to change the lock window picture but cant see the option anywhere.
I can confirm Start8 works really well, just like the old start menu.
Click and hold at the top of screen and drag all the way to the bottom.
Apps aren't meant to be closed, just go back to start screen. That way next time you use the app, it'll open instantly, rather than a few seconds.
ATM there's only one power app in the store and its £1.39 irc, I'm sure a free app will come soon enough, otherwise you can do this
http://www.howtogeek.com/77061/how-...rt-sleep-to-the-windows-8-metro-start-screen/
awesome, cheers for that , works a treatSo apps just sit in the background sucking up resourses?
Space bar for the lock screen instead of having to flick the image up etc makes a HUGE difference.
You can press any key or just click.
