Mechanical keyboard with out the number pad.
IC3
IC3
3 Dec 2011
Mechanical keyboard tenkeyless
Hi since my razer arctosa sometimes lags and doesnt work i decided its time to move on to something better that will last longer.
I wouldnt really want to go above 70 pounds.
I type a lot and i like to have a good responding keyboard in game.
Cherry red, brown and blue were the 3 types iv picked after reading some reviews. The cherry blue might be too soft and i think that cherry red would be just about right 50% typing 50% gaming.
As i said no number pad, i never use it and it takes space...
I dont mind buying the keyboard off different website (just to let you know)
So hopefully not to get the post deleted like before, you really only have the option to spend slightly more and to purchase http://www.overclockers.co.uk/showproduct.php?prodid=KB-007-CM&groupid=702&catid=23&subcat=2107
Atleast its like the rapid you previously posted and still from the same, good manufacturer.
It's a shame I cant help through the previous post but oh well. I believe this ones probably your best option. Its only 10% over your top budget hopefully you can stretch to it.
Its probably because you gave a different website.
You can give manfuactures website and makes, models etc.
What keyboard did you write previously? Just give me the model if you can. Cheers
I dont even know if I can state the reason for the deletion as it can still help you. And I recon still slightly go against the rules for the reason it was deleted in the first place.
If I was to supply you with a model number then it would probably be considered worse than the original post as well.
:eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
