- 15 May 2012
- Louth, lincs
By the end of next week should finaly be able to put my loop together, been waiting for pump
here is a rough diagram of bits and flow
red = components
blue = fans
what do ya think??? any suggestions
2. when filling the loop do i leave top off res and keep filling? whilst the pump is on.
3. For fitting a drain point, what do i need and do Ocuk have what i will require, position i was thinking of was just in front of lower rad as the dust cover is removeable so could drain out of bottom.
4. bleeding, again do i unscrew top of res to let air out???
thx
nick
edit, not sure if i can do it yet but would like to route the long tube from top rad to controller WB to the back of the case, where cables are, can you get tube to tube fittings, as i dont want to kink the tube.
red = components
blue = fans
thx
nick
