It's usually wise to wait a bit to let the bugs get ironed out and driver support to improve. Windows 7 was no different.
Right now I think you'll find windows 7 is a better bet than windows 8 and yes I have used the later![]()
This*
lad at work is going to send me a link later to get windows 8 for £25 (just the iso to downlaod! £50 for disk or £25 for iso and burn myself hmmmmm easy decision)
then going to wait a long while before upgrading , I'll have to deal with compatibility issues at work, can't be bothered to deal with them at home aswell![]()
.How about some real world insight as to how it actually runs with games?
From the few that I tried, FIFA 13 works but leaves all sorts of strange errors in event viewer, so it's not entirely happy. Also stutters and have to alt-tab out of a game, then back in. (Possibly latest nvidia beta drivers to blame though)
Dishonored and Sleeping Dogs seem to work fine, no noticeable difference while playing.
Got about 100 less points in 3D Mark 11.
Overall, it's snappy but feel like it's lacking the polish of Windows 7. Too many strange errors in event viewer, it's not happy with drivers for my cyborg RAT 7 or mech keyboard.
"Tool" sig. users only in this thread please
There won't be an alternative to metro UI. Unless you mod. So don't wait, it won't happen.
Seeing as you have a dodgy set up, not the best advice ever.
I'm running several games with no issues at all xcom and ksp.
No, you have hardware with is supported, hardware faults or something else dodgy. You seem to think everyone is affected and its win8 fault. You seem to want to hate you have so many posts saying similar things dating back days.
Yet the vast majority it works fine yet somehow you think it's win8 and just complain rather than digging deeper and googling error codes and seeing what the issue is.
Got an overclocked machine, unclock it. Just be use a overclocked or damaged component worked on old OS doesn't mean it'll work on new OS, tolerances get tighter in pretty much every new release and try googling error codes for a start. As seen in all the threads your experience is not common, so is u like to be a win8 issue.
Win8 has been super stable as well.
They believe this new interface is the future, so they defiantly wont change.
I choose option B... reinstall Windows 7.
I have been googling the error codes, everyone's solution is to reinstall Windows 7. Getting pretty frustrating to just be told everything is hunky dorey with Windows 8.
If the hardware was to blame then surely it would have showed itself in Windows 7 to some extent.
The more I look, all drivers and software that companies have flagged as compatible simply aren't.
Have a look in your event viewer right now and tell me what your seeing.
"Tool" sig. users only in this thread please![]()
