Driving a petrol after learning in a diesel
My cars have always had the petrol cap on the drivers side of the car. I recently bought a car which has the fuel cap on the passengers side.
Is there anything I should be doing differently at the petrol station?
Insert the nozzle on the left side.
Not too long, but I don't think you ever really get over "feeling" the difference. I definitely prefer the weightier clutch and effortless clutch-riding of a diesel. I've been driving a petrol for about 7 months now and STILL feel like a tool over-revving it when moving from stationary to avoid stalling. :(
Don't over rev it then. It isn't necessary. I rarely go over 1,500rpm and I'm able to pull away fine.
x2!
in my diesel I can go from 1st to 2nd to (at least) 3rd without even touching the accelerator; not that I do. Because a diesel is more torquey surely you are able to change gears earlier because even the tick over will provide sufficient power?
B@
I can go through all 6 gears in my petrol car without touching the accelerator. What prize do I win?
My point was the diesels I have driven tend to need plenty of revs before you can change up a gear. Yet in most petrols I've driven they will happily change up a gear and cruise along at 1k revs. A diesel will splutter and cry if you try and cruise around at 1k revs...
No difference, cars all have different biting points anyway.
Generally you have to rev a petrol engine a bit more to get it moving, in the torquey diseasels I have driven I could pull away without using the accelerator very comfortably, but you can't do that in a petrol.
Flat surface in 1st you should be able to easy ;)
I've recently cleaned the mass of tools out of my boot, should I be booking some extra lessons so I'm not caught out by the change in weight?
Only kidding OP, there's much more of a difference between different models of car than there is between general driving of a petrol / diesel. As a new driver it'll take you a few times out to get used to a different motor
It revs for longer and will stall much easier. In a diesel you can pull away on idle. That's it really, being a driving instructors car you wont be use to putting diesel in a car so no worries there. Just get use to biting point and pulling away, job done really.
I can understand the OP's post. He is moving from probably a very new driving instructors car to something totally different, maybe in age but certainly characteristics. Something experience drivers take for granted but going out in your own car for the first time is going to be nerve wrecking.
What's with all the revving up? I very rarely have any need to increase the revs from idle when pulling away. I used to drive an asthmatic 1.6 and that was just the same. Revving only serves to burn the clutch out.
A modern honda vtec will do that, its great how hard it is to stall a modern car. I still got nightmares of driving an old carb on a cold day.
Feather the clutch a lot is probably best, I tend to be in danger of going kangaroo with a new car thats greatly different. Hill start is worst :o
What car is that
All the people making sarky comments here probably learnt in a petrol then went to a diesel, it's much much easier that way, and would look simple from that PoV
What rubbish,its absolutely no different, like I said there's a vastly bigger difference between different types of petrol or diesel cars than there is switching specifically from a diesel to petrol or vice versa.
With everything a new driver has to learn / think about it'll barely register
I learnt in a turbo diesel astra and had a 1.3 petrol upon passing. There's not really much difference at all. Every car you drive will have a different clutch. Drive 5 miles though and you'll be used to it and probably never stall again with that car (if you even stall in the first place).
