Driving a petrol after learning in a diesel
What car is that
I can do it with all 5 gears in my petrol car, so can all my mates. In fact when me and my mates were all 17 and immature knob heads, we used to have 'clutch races' where literally all you do is go down the industrial estate find a long road and then start in first let clutch out slowly to get moving then go up the gears, whoever get to fifth first wins.
I went from driving an automatic for 5 years to a manual, It took me almost no time at all to adapt, apart from pulling off on the odd hill :-/
A diesel can't possibly be any different from a petrol.
I recently bought some new shoes, is there anything i need to do differently when i walk?
I know people are being funny but it is possible to screw up something simple easily. Like put a few cement bags in the back of some cars and it can give a bit of a surprise in handling under braking then turning, say a roundabout approach. Probably not most of the time but its possible ime
Maybe not applicable to most on this forum but re the quote above:
All the people making sarky comments here probably learnt in a petrol then went to a diesel, it's much much easier that way, and would look simple from that PoV
If the driver has driving experience and is a good driver, then you should be able to jump into any car and just drive it no problems. It makes no difference what so ever.
The Slow and The Tedious :p
I learnt in a turbo diesel astra and had a 1.3 petrol upon passing. There's not really much difference at all. Every car you drive will have a different clutch. Drive 5 miles though and you'll be used to it and probably never stall again with that car (if you even stall in the first place).
Yep I went from a manual turbo petrol to an automatic diesel and I haven't stalled once :D
No, I learnt in a diesel and then owned a Fiat Cinquecento, with about as much flywheel torque as a washing machine motor.
:D. Slowest street race ever? :p
What rubbish,its absolutely no different, like I said there's a vastly bigger difference between different types of petrol or diesel cars than there is switching specifically from a diesel to petrol or vice versa.
With everything a new driver has to learn / think about it'll barely register
I think the issue is switching from an instructors car (probably a 1.4L diesel) to a low-insurance petrol, probably 1L or thereabouts.
There's a pretty big difference!
It still doesn't take long to get used to it though.
I used to do something similar myself when I was 17 with my mates.
We also used to see who had the best clutch control and see who could pull away in the highest gear. Pulling away in 5th was never a problem, however the clutch never liked it!!
My Instructor swapped from a petrol mini to a diesel 207 half way through when i was learning.
I then drove another petrol mini ( cooper) the day i passed and bought a petrol fiesta 1.25.
I noticed no differences.
However my 306 gti-6 has the hardest clutch to use out of all of these cars.
Its more of a car by car issue in my eyes.
whilst thats true, I do firmly believe that there is a difference between the way you control the clutch and gears in a petrol compared to diesel and those differences can either help or hinder your general driving. so it is something to be aware of.
Whilst I can see where the OP is coming from, there is nothing really to learn, with time, I'm sure he'll pick it up!
That said, I do admit, when I jump from my Scania artic into my 318i, I do often think the clutch cable must have snapped in the car! By comparison, it feels like its not connected to anything!
Not that the trucks clutch pedal is over heavy or anything, they do feel very different though.
Truck or car, the clutch operates the same way, foot goes down, comes upto the bite point etc......
I've been driving a Citroen C4 diesel hire car for the last 3 days. Just got back into my 1.4 petrol Mini and nearly stalled when setting off as I yanked my foot of the clutch. The difference in clutch feel is huge.
No difference, cars all have different biting points anyway.
Generally you have to rev a petrol engine a bit more to get it moving, in the torquey diseasels I have driven I could pull away without using the accelerator very comfortably, but you can't do that in a petrol.
you can pull away in a petrol with just the clutch.
My point was the diesels I have driven tend to need plenty of revs before you can change up a gear. Yet in most petrols I've driven they will happily change up a gear and cruise along at 1k revs. A diesel will splutter and cry if you try and cruise around at 1k revs...
This is a load of bull. Not sure what diesel cars you've been driving...
The main thing I noticed between my own cars Peugeot 406 2.0 & Ford Capri 2.8i being the petrols & a pair of Rover 220's and a Mondeo Mk3 being the diesels is the engine braking more than anything.
Both the petrols were happy to be knocked into 2nd & let the revs shoot up at some speed for bends whereas the diesels tend to want to smash your face against the steering wheel if you try the same.
How long does it normally take to get used to driving a petrol car after passing your test in a diesel? I'm worried about the difference in clutch feeling as I've just bought a petrol car.
no difference at all really, I drive a diesel all day for work then get in my petrol and go home :p
You'll be fine.
I switched to a different instructor within the same company so went from a Fiesta > 208 and from heavy steering and clutch to much much lighter and then also had to drive a 308 which was back to heavy steering and clutch. From that I've learnt I like heavy steering and clutch :D
