29 Oct 2012 at 15:01 #1 sid-180 sid-180 Associate Joined 6 Nov 2009 Posts 551 Need a new HSF as the stock cooler that came with the cpu is too loud. CPU: AMD Bulldozer FX-8 Eight Core 8150 Black Edition Any reccommendations?
29 Oct 2012 at 15:27 #2 Bacon? Bacon? Soldato Joined 21 Apr 2012 Posts 4,991 Location Bristol A big one.
29 Oct 2012 at 15:37 #3 Orcvader Orcvader Soldato Joined 11 Oct 2009 Posts 16,964 Location Greater London Budget? Will you plan to overclock?
29 Oct 2012 at 15:52 #4 sid-180 sid-180 Associate OP Joined 6 Nov 2009 Posts 551 budget is max £50 although the cheaper the better, might overclock a bit.
29 Oct 2012 at 15:57 #5 Orcvader Orcvader Soldato Joined 11 Oct 2009 Posts 16,964 Location Greater London Assuming you have space in your case, how about this? http://www.overclockers.co.uk/showproduct.php?prodid=HS-095-TR&groupid=701&catid=2330&subcat=2352
29 Oct 2012 at 16:14 #6 sid-180 sid-180 Associate OP Joined 6 Nov 2009 Posts 551 no space for that beast
29 Oct 2012 at 17:14 #7 sid-180 sid-180 Associate OP Joined 6 Nov 2009 Posts 551 What about the following 2, would they fit on the following MB Gigabyte 970A-UD3 AMD 970A (Socket AM3+) http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS&groupid=701&catid=2330&subcat=2262 http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-AN&groupid=701&catid=2330&subcat=2262
29 Oct 2012 at 18:28 #8 UK_Overkill UK_Overkill Associate Joined 6 May 2009 Posts 3 I have that CPU, my stock cooler isn't noisy, maybe you have your speed too high?
29 Oct 2012 at 18:30 #9 UK_Overkill UK_Overkill Associate Joined 6 May 2009 Posts 3 No sorry, I have the FX 8120 but I have it oc-ed to 3.6GHz
29 Oct 2012 at 18:42 #10 Nevakonaza Nevakonaza Soldato Joined 7 Jan 2009 Posts 6,887 BeQuiet Shadow Rock Pro http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-BQ&groupid=701&catid=2330&subcat=2340 Prolimatech Panther http://www.overclockers.co.uk/showproduct.php?prodid=HS-012-PL&groupid=701&catid=2330&subcat=2349 Xigmatek Prime SD1484 http://www.overclockers.co.uk/showproduct.php?prodid=HS-013-XG&tool=3
29 Oct 2012 at 18:52 #11 foster grant foster grant Soldato Joined 10 May 2012 Posts 6,270 Location North London but dont the fans on those face down at the graphics card ? ...i myself am looking for an AMD cooler that faces the front and back of my case
29 Oct 2012 at 19:35 #12 sid-180 sid-180 Associate OP Joined 6 Nov 2009 Posts 551 I have gone and ordered the Corsair Hydro H60 High Performance. http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS&groupid=701&catid=2330&subcat=2262
29 Oct 2012 at 20:38 #13 foster grant foster grant Soldato Joined 10 May 2012 Posts 6,270 Location North London sid-180 said: I have gone and ordered the Corsair Hydro H60 High Performance. http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS&groupid=701&catid=2330&subcat=2262 Click to expand... I had the Antec 920...sent it back....but only cos the "Chill" software stopped running properly after only one day lol Last edited: 29 Oct 2012
