You beat me Greg![]()
Shocking advice bud. I had to jump in quick but I can see the OP isn't stupid enough to sell his system and buy the same/lesser (I7 to I5 geeeeez) system again....
Im not sure AMD cards can do 3D across 3 screens in crossfire mode. I dont think it works, but am happy to be proven wrong (in fact I hope im wrong). Just something you need to make sure of before going either way. Hopefully Tommybhoy or someone else can clear this up![]()
Thanks scotty....howcome though?
you will still suffer micro stutter and SLI problems.
YOU'RE WRONG!
Greg..if i went down the road of having a vg278h as as the middle monitor and was going to use it for 3d..do asus do a standard version of the vg278h without the 3d option?
Well it will have to be 3 VG278H monitors![]()
Sticking with nvidia mate, might be slightly more expensive but the pro's outweigh the con's for me. Just got to settle on the card/cards
snip
Was just looking at those...very tempted..wonder when they will be getting more in..
Would allow me to grab another ssd too and still be under my budget..
Mal!! Show yourself!
What exactly are the pros that you want to pay £200-300 more for exactly?
Make no mistake, 7950 crossfire is a faster in triple screen than 670's/680's.
The 690 is 2 cards still like explained already, it just uses 1 slot, you will still suffer micro stutter and SLI problems.
Other side is 2x 670s as they are just under 680 performance and 2x will beat a 690.
If your going to spend such money id rather sell your old PC in your sig buy a £1k system with a 680 inside it with an i5k then buy a second 680. Youll maybe spend a tiny bit more
