I have a Automatic '04 E46 320cd.
It's recently has randomly started producing a noise which I can only describe as a 'rumble', it come from the back of the car from what I can make out, it's not loud and does not last long, few seconds, tops. It also happens completely randomly and doesn't happen that often.
Having read around, I've discovered my car is running a GM made gearbox! and the torque converter is apparently the most likely culprit, I'm not convinced.
I'm trying to think of what else it could possibly be:
> Tyre tracking/balance?
> Engine Mounts?
> Differential?
The car pulls very well and smoothly in all gears, there is no loss in power or drop in revs etc.
Has anyone else experienced anything similar?
> Engine Mounts?
> Differential?
