Custom Windows 8 Tiles
7 Apr 2010
Cheltenham, Glos, UK
The tiles Windows 8 creates for your desktop apps just ruin the look of the (not)Metro screen.
However, I have come across a tool that allows you to create your own tile shortcuts to applications and use a custom image for the tile! Thank god!
The app is called OblyTile and can be found here: http://forum.xda-developers.com/showthread.php?t=1899865
It's very simple to use and can help (non)Metro on PC be that little less painful!
Also related, a great pack of Premade App Tiles: http://dakirby309.deviantart.com/art/Metro-UI-Dock-Icon-Set-678-Icons-280724102?
Update:
Decor8: http://www.stardock.com/products/decor8/features.asp - Change background picture of metro and other colour settings.
Game Tile Images:
http://www.neogaf.com/forum/showthread.php?t=497663 - Nice collection of tiles for games!
Enjoy!
Great work :) the app is very easy to use. One thing how do I get 30x30 img? If you zoom out of metro you loose the icons.
Thanks
I haven't seen this posted up yet. The tiles Windows 8 creates for your desktop apps just ruin the look of the (not)Metro screen.
Also related, a great pack of premade tiles: http://dakirby309.deviantart.com/art/Metro-UI-Dock-Icon-Set-678-Icons-280724102?
Enjoy!
I found that originally if you zoomed out using the same 512x512 image, it would disappear. However, after a reboot, when I zoomed out, the images auto resized. So it might auto-generated the 30x30 images.
Nice, thanks. I've just been playing around with it :)
Sweet man! The game images look sooo much better than the icons you get by default :D
Hyperst,
How do you know if you need a Program Argument? And if you do like you've posted above, where do you find out how and what to put?
Thanks mate :)
Well the instructions for that one was in the thread for the program as someone asked for it:) me personally I have no idea and just use google for answers :D I found the arguments for the shutdown and reset using google.
Anyone use Win8 with Nvidia Suround and Sli?? any desktop or performace problems?
I don't use surround but I use SLI, no problems so far:)
