My phone seems to have bricked itself for no reason whatsoever, I have not messed with any of the settings and other than a firmware update recently(which went fine) nothing has been changed.
I figured the battery might have run down fast as i have been in an area with no signal but when I got back and put it on charge it the indicator light didn't appear. It has not been dropped or had any water ingress(other than 4 months ago, so im ruling that out). The only thing I noticed today that was rather odd was that the phone turned itself off, I figured the battery had run low(it should have been on 40% at a guess). A few minutes after it that turned itself back on again and I thought nothing of it. The next time I check it, it's dead.
Its been on charge for a few hours now and i've tried the reset by holding the vol down button then holding the power button but no luck. I've also tried holding down the power button for various lengths of time just incase that would work
Is there anything else I can try??
I wouldn't be so bothered but i'm meant to be meeting up in london later in an area I don't really know and I don't want the person to think I stood them up. The only other method of contact is facebook but I don't know how often they check it. Unfortunately I didn't save the number to my sim and unless the texts are saved there really is nothing else I can do. I really was relying on my phone for this.
Brilliant timing........
