- 9 Mar 2009
If you were to go the water route, make sure your gpus aren't too long. You can fit in a magicool 2x180 rad in the ft02 (or 3x180 if you drill out the hdd cage).
I can't because the ltgs don't leave enough clearance for the rad.
For air, reference is the safe bet but other coolers may be fine.. it's hit and miss.
there's no issue with recirculating hot air, it's all forced out the roof, particularly on the vents beside the pci brackets.
