I'm looking into getting hold of some 25mm foil backed cellotec insulation board to try and make my downstairs loo warmer, as it is the coldest room in the house despite having a radiator in there.
Its a small room and 2 of the walls are external walls on the corner of the house. I was thinking of dropping the ceiling by a few inches so that the 2400mm board will be high enough and then gluing the 25mm insulation to the walls then gluing the plasterboard to that. Also bang some mechanical fixings in as well to make sure.
My question is; is it worth doing this? I have read that anything less than 50mm isn't worth bothering, but surely if they sell it in 25mm it must do something?
The 'Combined R-Value (m²K/W)' is 1.25. I have no idea what this means, but would this help to insulate the room so that it doesn't get so cold? The sheets cost about £14 each from ebay, so i'd only need 3 to do what I need, then the plasterboard and plaster on top.
TIA
TIA
