First off I recently built a new Rig beginning of September, All parts were bought from Overclockers.
I'm trying to work out if my G/card is faulty or is there something else making the G/Card to do this.
G/Card in question is Gainwood GTX680 4gb version.
I get this happen in some games
If I alt tab quick enough I get to see the following in the bottom corner
(yes I know, my monitor is dusty, after taking that shot I realised I should clean it more on a daily basis
Now the game showing is Shogun 2, but I've had this happen while playing games like Skyrim, BF3, HL2/Garrys Mod. Now the thing is, it isn't constant sometimes I can play for hours and nothing happen other times it happens after 10mins others it'll be couple hours.
Also I can play other games and it not happen at all, I've played Borderlands 2 for hours and its never happened, Minecraft with high rez texturepacks, DCSWorld, those are to name a few, and I've never had any of the above happen.
Usually when it happens If I alt tab I'll get that "Driver has recovered" (like the 2nd image above) and after a couple alt tabs back into the game (usually alt-tabbing back in the FPS is slugish, but I alt-tab a few times and its back to normal FPS) It'll carry on running like normal, sometimes it may crash again but usually it doesn't. Only game that really doesn't like it is Shogun 2, if I alt tab the game doesn't like it and wont Alt-tab back in.
I have AIDA64 Extreme running on my G19 and the temps for my CPU idle at around 27c and never really go over 35c (air cooled) and my G/card idles at around 33c and when playing games doesn't go over 70c (again air cooled) so I don't think its an over heating problem.
I'm running this on the ASUS Extreme V m/board (running the 0704 bios, its not the latest but can't see anything in changelog to do with this problem) with a i7 Ivybridge 3770k 3.5ghz and 16gb Ram, OS is a Win7 Pro 64bit
Nothing is overclocked, everything is running as factory set.
I just can't seem to work out what's causing it, my personal thoughts are if the g/card is faulty why doesn't it do it in every game? and why isn't it constant? which is same reasoning behind it not being a overheating problem.
Then again do I have a faulty one and its only when certain things happen it crashes the driver?
I just wanted to see what others think before I contact Overclockers to RMA the card.
