The curve is meant to go upwards.
Correct, then when weight is applied they should be then be a reasonable tight fit.
Always thought the plastic clip design is rather naff, got a ikea bed here, same problem.
Solve it by ditching plastic clip, & drilling right through the exsisting hole in frame & slat, then use a small M5,M6 bolt & nut right through to secure everything.
Looking at the slats I have, they could be a bit longer, for a better fit.
EDIT: Your bed frame looks slightly different to mine, so maybe self tappers to secure slats to frame or similar?
Just checked the bolts I used, steel countersunk BA1,BA2.
Second question they are right slats for the bed, box hadn't been tampered with?
