Not getting any artifacts or temp issue's with this , but i do get a burning smell after 30-45 mins of sustained gaming (highest temps in bf3 ultra settings 1920/1080 of 71 deg) hell of a whine from the fan at those temps (53-62%) i dont let it get over 63% because it sounds like an aeroplane, its just ive had many amd card's and not once had to put this kind of voltage through a chip
hi what do you mean by plastic left on the card ? - i have visually inspected the card (when i first smelled the burning ) apart from discoloration of the solder on the back it all seems fine ,
Sorry to bump an old post but its relevant to my question.
I have the same card same boost bios.
For me it doesn't cause any stuttering or anything it just means i cannot overclock the card properly.
When it "boosts" the voltage appears to raise to 1.25 but in actuality when monitoring in afterburner it doesn't it fluctuates up and down from 1.000 to 1.080. At voltage 1.080 i cant overclock the card beyond 950.
I can force constant voltage in afterburner and this works ive raised the voltage to 1.175 and have a conservative stable overclock of 1100/1400. The biggest problem about this is then the voltage doesnt reduce when idling on the desktop.
Ideally could do with a stock none boost bios that is compatible with the ICEQ card as don't think i can just use any old bios as its a none referance design?
