With respect, I don't think you fully understand how TDP works and your comment "I think it's wishful thinking", is your wishful thinking.
The TDP can be 1000w or 50w, less than 10% is what the actual power usage difference is.
Give it up Humbug. Digging deeper when you should have just left it alone![]()
Is the 780 going to be the big Kepler then with better than atrocious compute power?
Regardless, I think nvidia is in a strong position. A 680 with a 384-bit bus would have a similar heat output to a 7970, possibly even less, but would outperform it. It remains to be seen though if they can make a big chip with decent clock speeds and some compute power with decent yields.
Only Nvidia will know what they will be releasing and right up untill release, we will hear many rumours of which 99% will be wrong. NviDiA (NDA will be in full force) and I wish they would give out a little info but that won't be happening![]()
Because higher TDP goes hand in hand with higher power consumption - ergo, a card with a lower TDP typically has lower power consumption such as the 680 does with respect to the 7970. Which has already been pointed out means that Nvidia can boost performance merely by beefing up the existing design.Explain how a lower TDP gives more power head room than one with a higher TDP, and do it without ignoring actual power consumption results.
It feels like Nvidia are reaching the max potential of the architecture and not able to make such great leaps from series to series.
I can see AMD having the faster cards when the new cards do get released.
True. All I want to know to begin with is will they be voltage locked? If so, team red again for me.
You do realise that the two are linked - if it's too small the card overheats and burns out, too big and the cooler is oversized for the duty and makes it cost more than it needs to. It's not plucked out of thin air!^^^^ Yet in practice its actually only 10% at best, you can give a device a TDP plucked out of thin air, what matters is what its actually doing.
Are you kidding me?
You keep on about power but this isn't the point. Kepler uses a lower TDP, it is cooler at running than Tahiti.
Basic common sense tells you that something cooler has headroom to give more grunt. I am no expert on dye sizes or compute technology, Duff man/Xsistor/Drunkenmaster will bring you up to speed on these things but the TDP shows that Kepler has more to give than it's AMD counter part (unless AMD can get it running cooler).
Its not that simpe Gregster. AMD could easily have released the 7970 at 1.1v and the TDP/heat output would be a lot closer to the 680. It would obviously have a lot less over clock headroom though on stock volts, also similar to the 680. As a result of this they had almost certainly had better yields than the 680, but higher heat output.
Think of it another way, if the 680 was released locked at 1.225v they would have had a higher TDP, and higher over clock headroom at stock.
This isn't true by the way...the device which actually uses less power in practice, is the one that runs cooler, fact. yes.
SB or IB
Which one is cooler? SB
Which one uses less power? IB
What I'm saying is the 7970's were released with artificially high voltage for their clock speed. Hence the high over clock headroom. They could have easily been released at 1.1v and have a lower TDP, which is why TDP isn't everything.
We know Kepler is more efficient however from the 7990 vs 690.
What we don't know is how much the difference can be attributed to the extra vram, 384-bit bus or the extra compute units.
For the 8xxx GCN could be stripped of gpu compute units and instantly it is far more efficient and has a lower TDP, think Pitcairn. A Pitcairn scaled up to 350mm^2 would have nvidia worrying.
