A golden clocking 7970 lost forever.
I hope you had a minutes silence.
Yep
I now at least have a reason to upgrade to a BE, as for the motherboard I can still request refund so may just go for the rive.
the vapor x 7950 I believe have weaker vrms and a halk locked voltage controller. you want the older sapphire 7950 oc that runs at 900/950. They have dua bioses to enhance oveclocking.
As for the vapor x There was a thread on here where someone proved they could unlock it but it was very fussy on the software it needed.
found it http://forums.overclockers.co.uk/showthread.php?t=18449100
^ the kfa2 ex oc is a good card, UK based rma too should you ever have to use it.
I am not sure why KFA2 get over looked (maybe the crappy connections) but with them being UK based, this should certainly help our decisions in buying. If they sort out the connections, I will be looking at them for my next purchases![]()
http://www.overclockers.co.uk/showproduct.php?prodid=GX-030-KF
Not at all. I just don't like the connections (not one D-DVI on this card)
Isn't there adapter from minihdmi to dvi? do ocuk sell them?
There is (not sure if OcUK sell them) and they work a treat. I wouldn't want to spend extra on a connection though when I can get a different card with the connections I want.
True, but that card seems to best. When buying my next card MSI isn't even on my mind.
I can't say I blame you and you did ask me what is the best 680....KFA2 are where I will be looking next time to be honest.
Thanks gregster. You've been a great help. cheers![]()
