** NEW CORSAIR LCS OFFERINGS AT OCUK **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Released today and currently en route to OcUK, we are pleased to be the first to list these fantastic new coolers from Corsair for pre order.
Featuring improved fan designs and built in Corsair Link Technology in the cooler itself, the H80i and H100i are the most advanced Closed Loop Liquid Cooling solutions available to date.
At the start of the range, the Corsair H55 offers quiet cooling at an affordable price point for users who are concerned with value for money but still want a superb performance cooler.
Due to land any day now, pre order now to avoid disappointment!
Corsair Hydro H55 Quiet Liquid CPU Cooler (Socket LGA2011/1366/1155/1156/AM2/AM3FM1) @ £49.99 inc VAT
The Easy CPU Performance Upgrade
Your PC will run cooler and quieter when you replace your CPU’s standard heatsink with a Hydro Series H55.
Installation is straightforward: if you can get to the back of your PC’s motherboard, you can install an H55. All you’ll need is a screwdriver.
Great for Smaller Cases
The compact components and flexible tubing make Hydro Series H55 easy to install even if you’re cramped for space. It allows you to improve your CPU’s cooling efficiency even in most compact cases — as long as your case has a 120mm fan mount near the CPU, H55 will probably fit.
Self-contained cooling system
Hydro Series H55 comes pre-filled, and never needs refilling or priming.
Tool-free mounting bracket kit
The modular design makes installation simpler, and it’s compatible with Intel and AMD processors.
Low-noise, low-speed 120mm fan
The low speed and wide diameter reduces noise levels over the smaller, faster fans used on stock CPU coolers. The three-pin connector is compatible with fan controllers.
Low permeability rubber tooling
Minimal coolant evaporation helps ensure long life, and the resilient rubber offers both high flexibility and excellent leak protection.
Low-profile pump
The pump unit provides high-speed circulation without taking a lot of space. This makes installation easier, and helps improve your case’s airflow.
Latest generation micro-fin copper cold plate with pre-applied thermal compound
Copper has excellent thermal transfer characteristics, and the fin design is optimized for efficient heat exchange.
Low-profile black aluminum heat exchanger
The low-profile design reduces the airflow requirement, which helps make H55 quieter. The small size also allows for easier installation and improved compatibility, and the black finish looks great.
Package contents
Corsair H55 Liquid CPU Cooler
One 120mm fans
Mounting screws for fan and radiator
Mounting brackets for Intel™ LGA 115x/1136/2011 and AMD AM2/AM3
Quick Start Guide
Technical Specifications
Radiator dimensions: 120mm x 152mm x 27mm
Fan dimensions: 120mm x 120mm x 25mm
Fan speed: 1700RPM +/- 10%
Fan airflow: 57 CFM
Fan dBA: 30.32 dBA
Fan static pressure: 1.9mm/H20
Compatibility
Intel LGA 1155, 1156, 1366, and 2011
AMD sockets AM2, AM3 and FM1
Only £49.99 inc VAT.
ORDER NOW
Corsair Hydro H80i High Performance Liquid CPU Cooler (Socket /LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3/FM1/FM2) @ £82.99 inc VAT
High-Performance CPU Cooling
Protect your hardware and increase your CPU’s overclocking potential. Dual fans and a double-thick radiator deliver outstanding cooling efficiency.
Advanced Fan Design
The 120mm fans use custom-engineered blades for better static pressure to noise ratio, offering improved performance at lower noise levels.
Corsair Link Monitoring and Control
Monitor temperature and control lighting and fan speed on your screen. No additional hardware is necessary.
Self-contained Cooling System
Hydro Series H80i comes pre-filled, and never needs refilling or priming.
Built-In Corsair Link
No additional hardware is necessary – just connect the included Corsair Link cable to a USB header on your motherboard and download the free Corsair Link Dashboard software. You can monitor coolant temperature and adjust cooling performance directly from your desktop.
Tool-free multiplatform magnetic mounting bracket kit
Large-diameter, low permeability tubing
Minimal coolant evaporation helps ensure long life, and the resilient material offers both high flexibility and excellent leak protection.
• Corsair Hydro Series H80i High Performance Liquid CPU Cooler
• Magnetic Multi-platform mounting kit for all modern CPU sockets
• Dual SP120L High Performance Fans
• USB Cable for Corsair Link™ Compatibility
• Fan and radiator mounting screws
• Thermal compound (pre-applied)
• Quick Start Guide
• Technical Specifications
• Radiator dimensions: 120mm x 152mm x 38mm
• Fan dimensions: 120mm x 120mm x 25mm
• Fan speed: 2700 RPM
• Fan airflow: 77 CFM
• Fan dBA: 37.68 dBA
• Fan static pressure: 4mm/H20
Compatibility
• Intel™ LGA 1155, 1156, 1366, and 2011
• AMD™ sockets FM1, FM2, AM2, and AM3
Only £82.99 inc VAT.
ORDER NOW
Corsair Hydro H100i High Performance Liquid CPU Cooler (Socket /LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3/FM1/FM2) @ £91.99 inc VAT
Extreme Performance CPU Cooling
Have a PC case that supports a top-mounted 240mm radiator? Take your CPU cooling to a new level. H100i starts with the advanced design of the Hydro Series H80i, and adds a double-wide radiator for even better performance.
Hydro Series H100i comes pre-filled, and never needs refilling or priming.
Dual Radiator with Custom Fan Design
The 240mm top-mounted radiator provides maximum surface area for maximum cooling power. The 120mm fans use wide, low-pitch blades for better static pressure to noise ratio, offering improved efficiency at lower noise levels.
• Corsair Hydro Series H100i High Performance Liquid CPU Cooler
• Quick Start Guide
• Radiator dimensions: 120mm x 275mm x 27mm
Compatibility
*Hydro Series H100i requires a case with dual 120mm fan mounts with 15mm spacing for a 240mm radiator
Only £91.99 inc VAT.
ORDER NOW
Corsair H100i vs NZXT X60 vs Cooler Master Eisberg 240L, let the battle commence!
Corsair 5 year warranty is impressive though, I had to RMA a 200MM fan last week, did it direct through Corsair, only took 3 working days.
I doubt there will be much competition tbh Corsair will come out on top in the end.
I think it will be quite even between the H100i, and NZXT X60, but the NZXT X60 comes with a bigger rad - 138.4 x 27.0 x 312.5mm as opposed to the 120mm x 275mm x 27mm of the H100i.
Wish they had made them 38mm thick like the H80i.
Maybe buy both and tell us ;)
I'll wait a few months. Still have a h100 here that makes more ticking noise than the old school Fiesta engines did.
Their warranty service utterly sucks too, given you have to send it abroad. 5 Years or not - it costs 1/4 of the cooler price just to send it back.
Warranty service has been much improved recently.
The new tops are much better. Corsair quoted a load of changes in the last meeting we had with them.
You've got to be able to not only talk the talk, but walk the walk RJ! Once bitten twice shy!
If they have no issues in a few months I'll order one. Until then however, my h100 is a cracking expensive paperweight!
I've only found out about Corsair wanting RMAs sent to Holland in the past week. Getting a pair of faulty speakers (purchased from OCuk) swapped was going to cost me 50% of what I paid for them.
It took a transatlantic phone call (from work thankfully!) to get Corsair to agree to arrange a UPS collection at their expense.
Send it back to Corsair and kick up a fuss, you might get the new H100i back. ;)
