Today Only Deals!
Avexir MPower Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (AVD3U24001004G-2CM) @ £59.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower series is designed to be a perfect visual match for MSI Mpower mainboards and certain models of Asrock mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Yellow high performance heatspreaders
- Blue LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 10-12-12-31
- Dual Channel Kit: (2x4GB)
- 100% tested at 2400MHz in Intel & AMD based motherboards
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Only £59.99 inc VAT.
ORDER NOW
Asus Vulcan ANC Noise Cancelling ROG Gaming Headset @ £46.99 inc VAT
The persistent commitment of the ASUS ROG team promises to provide the leading performance gaming products merged with the excitement of gaming with a unique, stylish and gamer-focused design. Join the Republic of Gamers and stand out from the crowd.
<br><br>
ASUS has released the ROG Vulcan ANC, the world's first active-noise-cancelling pro gaming headset designed to immerse users into games and keep them free of distractions like never before. Created from the needs of competitive pro gamers to remain focused during competition, the ROG team forged the Vulcan ANC with both performance and comfort in mind. The Vulcan ANC features 85% active noise cancellation to filter out sounds like low frequency computer fan noise and 30dB passive noise cancellation to reduce a wide range of ambient noises, including background voices.
<br><br>
The Vulcan ANC not only provides gamers an immersive gaming experience with noise cancelling features, but also a comfortable one. The lightweight design of 320g is lighter than other comparable models of the same size, with other headsets weighing around 350g. Soft memory foam encased in breathable Japanese protein leather ensures user comfort even after extended gaming sessions. It is also portable, with a foldable design that easily fits into a durable touring case to take between competitions or LAN parties.
<br><br>
The Vulcan ANC is built with enlarged 40mm headphone drivers for crisp, clear audio. ASUS audio experts optimised the headset for a wide sound stage so audio is balanced with both thundering bass and brilliant mids and highs. A stylish blade-shaped detachable boom microphone has built-in noise filtering technology so teammates hear clear conversations during games instead of ambient noise.
<br><br>
Awards:<br>
<b>Bit Tech - Premium Grade Award - 92%</b>: "The Vulcan is a fantastic buy and our choice for a premium gaming headset."
<br><br>
<b>Hardware Heaven - Recommended Award</b>: "An excellent entry into high end gaming audio from ASUS which puts them right into competition with well-known brands such as SteelSeries and Razer."
Kit Guru - Must Have: "Our general impressions of the Asus Republic of Gamers Vulcan ANC headset are very positive; the sound quality and performance are bang on the money and the innovative ANC feature is something we've never seen before on a gaming headset."
Key Selling Points:
" Active-Noise-Cancelling (ANC) Technology: 100% Focus to win your game even in noisy environments, 85% active noise cancellation (for low frequency computer fan noise), 30dB noise isolation (for high frequency human and environmental noise).
" Long-lasting Comfort: Lightweight at 325g, Complete over-ear coverage, Ultra-soft breathable cushions with memory foam
" Immersive Audio: 40mm drivers deliver crystal-clear and directional audio details and the fine-tuned chamber space provides a wide sound field
" Rugged Carbon Shield: Scratch-resistant carbon shield keeps the Vulcan ANC looking sharp, even after heavy use
" Gaming with Style: Stand out from other gamers with a stylish ROG product design
" Rigid Touring Case: Solid construction for enhanced headset protection during travel when in compact and folded.
" Durable & Detachable Cable: Strong cable durability with a diameter of 3.5mm. Exclusive detachable design for cable placement and customization
" In-line Volume Control: Easily adjust or mute the volume with a compact, clip-on volume control
" Detachable noise-filtering microphone: Built-in noise filtering technology so teammates hear clear conversations during games instead of ambient noise
" Award Winning: 2 awards from the UK media in the first month of release.
Key specification
" Driver Driver Diameter : 40 mm
" Frequency Response Headphone : 10 ~ 20000 Hz
" Impedance: 32 Ohm
" Noise Cancelling Performance
" Active : Maximum > 15 dB, 85 % ambient noise cancellation
" Passive : Maximum > 30 dB
" Operation Time Listen Time (per charge) : Up to 40 Hours
" Dimensions: 21 x 18 x 7 cm
" Weight: 325 g
Connector:
" 3.5mm stereo plug (mic)
" 3.5mm stereo plug (Headphones)
In The Box:
" Carrying case
" User Guide
Only £46.99 inc VAT.
ORDER NOW
Features:
- Black PCB
- Lifetime Warranty
ORDER NOW
<br><br>
<br><br>
<br><br>
<br><br>
Awards:<br>
<br><br>
Key Selling Points:
Key specification
" Impedance: 32 Ohm
" Weight: 325 g
Connector:
In The Box:
" Carrying case
" User Guide
ORDER NOW
