I've been using prime95 for yonks now but wanting to try something new. I'll be stressing a i5 3570K, don't know if that matters though or if certain tests suit certain cpu's better.
What recommendations would you give?
^As the two chaps above suggested, IBT, just don't do what some fools do and set it to do 50+ runs so they can say "look my OC is stable".
IBT will usually snuff out instabilities inside the first few runs, personally I do 5 at the most, but nothing will tell you if its truly stable until you start playing your usual games etc...and obviously keep an eye on temps at all times with IBT, it will churn more heat from your CPU then just about any game and even more then prime...
Sod That!
