**ALL OcUK LAPTOPS NOW COME WITH AMD HOTFIX APPLIED & FREE GAMES - BENCHMARKS INSIDE!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some of you are aware of the Enduro issue AMD have had with their Radeon Mobile graphics chips when used in Intel mainboards having an un-desired effect on performance:-
The laptop I tested was:-
OcUK Limited Edition P170EM 17.3" LED Full HD Intel Processor, 1600MHz DDR3, SSD + HDD, ATI HD 7970M 2GB GDDR5 Graphics Card - Windows - Black @ £999.99 inc VAT
This Limited Edition of 10 units only now makes it possible to have a state of the art hardcore gaming laptop for under £1000. Though we do recommend customising the laptop with more memory along with additional storage. But now you can have an Intel based 7970M powerhouse of a gaming laptop all for under £1000, though you can also spec the system up with options that take it beyond the £1000 price too. Rest assured the 7970M graphics in this laptop can handle any game with ease.
For hardcore gamers the OcUK Extreme P170EM is the perfect choice. There is no more powerful or better constructed option, with the latest Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Extreme P170EM with an Intel I7 Extreme processor too.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system feature an ATi Radeon 7970M with 2GB of GDDR5 dedicated memory for absolutely blistering performance. Infact this is the fastest gaming laptop we sell and more importantly its also one of the best value and offers you the ability to tailor to your exact needs.
With a backlit keyboard you will no longer have problems finding the keys during the dark or whilst playing your favourite shoot 'em up! Not only that but with a choice of colours to suit your environment and taste your notebook will look more stylish than ever!
With a LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 7970M onboard graphics. The OcUK Extreme P170EM feature a blue backlit keyboard and high quality THX speakers for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Extreme P170EM causing zero bottlenecks in the system.
For hard drive options, we recommend the primary drive as an SSD drive, this means from point of pressing power on your should be at the Windows 7 Desktop in approx 10 seconds and with an SSD applications and games load more or less instantly. Of course if you preferre capacity you can choose a large capacity HDD or a Hybrid drive too. Our recommendation is to select an SSD for the primary drive along with a HDD as the secondary drive for storage.
Specification:-
- Operating System: Choose from the drop down options!
- Display: 17.3" SuperBright LED True HD Display (1920x1080 Resolution)
- Graphics: AMD Radeon™ HD7970M 2GB GDDR5
- Storage: Choose from the drop down options!
- Optical: Choose from the drop down options!
- HD Audio
- Mic Noise Suppression
- Dolby Home Theatre®
- 4W Stereo Speakers (2W x 4)
- Subwoofer
- 2 megapixel Webcam
- Processor: Intel® Core™ i5 / i7 Processor - Choose exact model from drop down options!
- Physical Specification: 412mm x 276mm x 41.8~45.4mm (3.9kg with battery)
- Memory: 4GB DDR3 System Memory at 1600MHz (4GB x 1) OR choose 8/16GB DDR3 Options
- Main Chipset: Intel HM77
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- Intel Centrino Wireless N 2230
- Bluetooth Connectivity
- Bluetooth 3.0
- 1x HDMI Port
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x E-SATA
- 1x DVI-I
- 1x DisplayPort
- 1x Microphone IN
- 1x Headphone OUT
- 1x DC IN
- 1x RJ-45 Jack
- 1x IEEE 1394a
- Kensington Lock: YES
- 8 Cell Smart Lithium-ION Battery
- Fingerprint Scanner
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Extreme P170EM", perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 48 and 96 hours for your system to be built and configured. This may take longer during busier periods. You can choose from the drop down options to jump the queue by selecting one of our Fast Track options. If your choosing the 24hr next day service, to get the laptop delivered next working day you need to order pre 10:30am to give us enough time to build, test and get your laptop shipped out, otherwise you will get it the following day.
Only £999.99 inc VAT.
ORDER NOW
BENCHMARK RESULTS!
Heaven before Hotfix
Heaven after Hotfix
3D Mark 11 before Hotfix
3D Mark 11 after Hotfix
As you can see the improvement is very noticable, it gives upto 40% additional performance in games, which means the 7970M is now as fast as the desktop 7870GHz cards and in some situations faster. Even more impressive 7970M now competes with 680M.
Also all OcUK Radeon 7970M laptops now come with:-
AMD Ultimate Never Settle Bundle - FARCRY3, Hitman Absolution, Sleeping Dogs & MOH Warfighter PC Games FREE with 79xx series Graphics Cards - Voucher @ £79.99 inc VAT
Get the latest yet to be released FARCRY3, Hitman Absolution, Sleeping Dogs and 20% of Medal of Honor Warfighter PC Games when you buy a qualifying 79xx series graphics card from Overclockers UK.
- FREE with AMD Series 79xx series cards for all purchases from 22/10/2012
- Subject to availability
- Codes will be emailed/posted to customers Friday 2nd November.
- When you order a 79xx card you shall get this included automatically in your order, so no need to actually order this product, otherwise you will be charged.
Only £79.99 inc VAT - FREE with 7970M based OcUK Laptops!
ORDER NOW
OcUK laptops come with the latest drivers and as you can see the performance is absolutely top notch! :)
Amazing deal I have ordered one, you guys beat everyone in price with all these free games its an unbeatable deal, I will be recommending family and friends to your store plus the 24 month warranty (12 month parts) is another good deal clincher at no extra cost better than most other pcbuilders.
Excellent, hope you enjoy it and let us know your thoughts after you've had it a few days. :)
Gibbo any chance you guys will be selling some compact gaming laptop based on the Clevo W110ER or similar? Have seen some competitors selling them with partial customizable options, so I'm curious if you guys would be doing the same?
