Project: Blackfenix (WIP)
So here is my Bitfenix Prodigy build, decided to move away from full towers as all my gaming is done in the living room now.
ALL PICTURES BELOW ARE FROM THE WIP STAGE! When complete there will be high quality/resolution pictures taken.
Specifications:
Modifications done:
Modifications planned:
WIP Pictures!
Sleeving work:
Modifications:
Benchmarks:
More to come
Specifications:
Bitfenix Prodigy Midnight Black (Of course
Intel i5 3570k @ 4.4GHz (Stock volts)
OcUK branded H80 AIO
Asrock Z77E-ITX
8GB Black Dragon 1600MHz
MSI GTX570 Twin Frozr III Power Edition
2x 120GB OCZ SSD (RAID 0)
Corsair TX550M PSU
Zalman ZM-MFC1 Plus Fan Controller
1x 200mm Bitfenix Spectre Pro Red LED
2x 120mm Bitfenix Spectre Pro Red LED
Razer Naga Molten Edition
Q-Pad MK-85 (Red switches)
)Intel i5 3570k @ 4.4GHz (Stock volts)
Asrock Z77E-ITX
Corsair TX550M PSU
Modifications done:
- Paint front fascia surround black from silver
- De-badge and relocate (Carbon Fibre wrap and magnet) >>>Clicky<<<
- Add LED's to inside panel adjustable via fan controller
- Add LED's to underside with 'fade' effect controller >>>Clicky<<<
- Replace power/HDD status LED's with red ones from the original blue >>>Clicky<<<
- Sleeve 24pin/8pin with paracord 550 (Black, Charcoal Grey and Red)
- Replace plastic side panel thumb screws with higher quality metal screws >>>Clicky<<<
- Silver Zinc WASD/ESC key caps >>>Clicky<<<
- USB blanking caps to hide blue USB ports on front panel
- Sleeve GPU power (6pin PCI-E x2)
- Sleeve front panel connectors >>>Clicky<<<
- Sleeve fan cables and Molex/SATA power
- Create 'blanking' plate to hide cabling on sides of PSU bay
- Under motherboard lighting
WIP Pictures!
Sleeving work:
24pin Sleeved in paracord
8pin and 24pin Sleeved in paracord
My first practice cable
6pin PCI-E's
Front panel connectors
6pin PCI-E's
Modifications:
Carbon Fibre Case Badge
Front Panel Status LED's
Thumb Screws
Key caps
Thumb Screws
Key caps
3DMark11 (Performance)
Heaven 3.0 (Maxed)
CrystalDiskMark:
ATTO:
IntelBurnTest:
Temps:
(1hour of Prime95 Blend):
Heaven 3.0 (Maxed)
CrystalDiskMark:
ATTO:
IntelBurnTest:
Temps:
More to come
quite a bit more to do sleeving wise.
