Change te board to Gigabyte, the psu would still be an overkill
650w would do just fine with plenty of power left.
Yeah plus high wattage PSU's doesnt really like low wattage systems, as they dont perform aswel using small amounts of power.
800, i've got PSU and case already
My PSU is hybric antec 750w bronze and case is Coolermaster Storm Trooper. I've got it already and can't change it.
That SSD is for system and some games (BF3, etc). I also want to record some videos for yotube everyday(HDD use).
From what i know playing games on SSDs give them FPS boost as they load textures and whole areas much faster.
I would prefere not to use MSI for GPU because from the expierience of many of my friends... They are faulty.
My budget is 800, and i can't go over 810... I just can't.
3GB XFX Radeon HD 7950 Double D, Black, Ghost/HCell, 5500MHz GDDR5, 900MHz, 1792 Cores, HDMI/mini DP+Free Games
£239.75inc VAT
HOT SELLER Intel Core i5 3570K,1155, Ivy Bridge, Quad Core, 3.4GHz, 5 GT/s DMI, 650MHz GPU, 6MB Smart Cache, 34x Ratio, 77W, OEM
£172.68inc VAT
NEW 250GB Samsung 840 Series Basic, 2.5" SSD, 3-core MDX, 21nm Toggle NAND, Read 540MB/s, Write 250MB/s, 96k IOPS
£149.10inc VAT
HOT SELLER Gigabyte GA-Z77-D3H, USB 3.0 Intel Z77, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0, D-Sub/ DVI-D/ HDMI, ATX
£77.72inc VAT
1TB Seagate ST1000DM003 Barracuda 7200.14 SATA 6Gb/s 7200rpm 64mb Cache 8ms NCQ OEM
£55.32inc VAT
8GB (2x4GB) Corsair DDR3 XMS3, PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-24, 1.65V
£26.59inc VAT
Phanteks CPU Performance Cooler Premium Red Edition w/ 2x 140mm Red Silent Fans All Intel/AMD
£57.58inc VAT
HOT SELLER Pioneer DVR-219LBK 24x DVD±R, 12x DVD±DL, DVD+RW x8/-RW x6, RAM x12, SATA, Black, OEM Labelflash
£15.70inc VAT
Alltogethert price-820 including 11 for shipping.
Final one?
Aren't that HDDs from green serie slow to keep them quiet?
Not true, PSUs are at their most efficient at around 50% loading.
They have slower RPM speeds yes, but ultimately you should really only use a mechicial drive as storage these days and an SSD as a boot drive so it shouldn't matter.
Change that XMS3 stuff for Vengeance LP as you don't want 1.65v for Ivy/Sandy. I'd recommend the Thermalright SB-E Extreme which is £50 at the place you are purchasing from. Makes it a bargain!
Also pay the extra (imho) for a Intel Retail CPU, you get an extra 2 years warranty and they tend to resell better.
Guys, you cant discuss a competitors pricing as it is easily searcheable and is bad for OcUK business.
Id recommend you discuss components and keep the exact prices out of it.
ON TOPIC:
750W is WAY overkill for that system mate
.Most high end coolers perform pretty similarly really, it is more down to the way they look (if your case has a window), the price and the fans. I went with the SB-E due to the price and looks, then sold and changed the fans as I didn't like the colour.
Yeah thats what I was meaning, but most systems pull a max of 300-400watts, unless youu've got 2 or more gpu's in your rig. So a 700+watt psu would be a overkill, and the psu wouldn't be able run efficiently. Also when your just messing in windows your system will only be pulling about 150 - 200watts
How much roughly will my i5 [email protected], Radeon 7950 stock, 750HDD. How much watts?
I was thinking roughly 250-300w while playing games.
I think abouth 100w at the maxium. Since my cpu while browsing takes 8-15w and the gpu around 30-50w.
Well my system pulls roughly 150watts from the wall when messing in windows and 300watts when gaming (System in sig)
