How do you open microsoft paint in windows 8
Caporegime
27 Nov 2005
Guernsey
HELP!!!!!!!!! :o
With no start menu in w8 how do I open stuff that would normally be under the start menu like microsoft paint ??...:confused:
Windows Key + R and type mspaint and hit enter OR Windows Key + F and search Apps for Paint
You could also pin it to the Metro start menu thing if you find it in apps then right click on it and Pin it from the bottom menu.
Start UI > Right click in empty space > All apps > Paint
Desktop > Ctrl+alt+del > task man > file > run > MSPAINT
Desktop > Move mouse to bottom right hand corner > Search > Paint
:)...Thanks guys...:)
I guess it going take me a while to get used to this w8...
Wondering how long I can hold out before installing a start menu app
Sorry for starting yet another w8 thread....:o
It will also start listing the programs you use most in the top of the list, so it's handy to be able to just ''Start'' type ''p'' hit enter
