Not a very bright thing to say !, clearly something is bending and flexing to allow the cooler to intermittently knock against the GFX card ! assuming also the thing starts off with 6-10mm static clearance
Not too bright huh?... Do you have any evidence to support this claim?:
really you should not have massive unsupported coolers hanging from a vertically mounted motherboard anyway
Clearly, you're posting urban myth and presenting it as fact.
Unless the pc is bouncing around in a car boot, you're talking rubbish.
Why do you think most cases come with a cutout allowing you to more easily install cpu cooler backplates? What does the backplate do? Define 'unsupported' and 'hanging'.
Do you own a large cooler?
Making assumptions about the amount of clearance available and then making more assumptions about the cooler somehow moving up and down in the region of a few mm isn't too bright in my opinion tbh.
If that was the case, it'd be down to being poorly mounted and his cpu contact would be terrible + bad temps would be clear to see.
Maybe you're of the 'big coolers bend/break motherboards' school of hilarity.
My own 'massive' cooler is about 1-2mm into the first PCIEx1 slot, rendering it almost unusable, although I've never tried to use it.
This is a common issue when using large/wide coolers with boards that don't have a PCIEx1 slot above the first x16 slot (see many X79's for example).
I'd ask the OP if the fan clips are in contact (or very, very close) with the gpu before assuming the cooler's moving up and down at those kind of distances.
If so, then yes, fan vibration could be enough to cause issues if contact alone isn't enough.
If it is sagging, then the bolts need to be checked as that shouldn't happen.
