- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
The new Xigmatek cases called the Alfar are due to arrive the start of December.
With great looks and styling, get this added to your Xmas wish list.
Xigmatek Alfar Midi Tower Case - All Black @ £42.98 inc VAT
The Xigmatek Álfar mid-tower gaming chassis continues Xigmatek’s tradition of offering great value and performance in a mid-tower chassis. However, the Álfar is part of Xigmatek’s new generation of chassis with an emphasis not only on ergonomics and usability, but also on aesthetics as well. The gently sloping front bezel has small mesh accents which gives the chassis its clean, simple lines, but also suggests a more racy and aggressive side. With the growing popularity of 2.5” SSDs, the Álfar is designed to accommodate up to five 2.5” devices, while still maintaining an ample complement of 3 x 5.25”external and 4 x 3.5” internal drive bays. As with all of Xigmatek’s chassis designs, careful attention was given to convenience and performance features such as the ability to mount 330mm full-length graphics cards and up to 160mm tall side-blow tower coolers; cutouts to ease the mounting of coolers and for cable management are all standard features. Support for the latest USB 3.0 is interface standard is also built-in along with ample cooling capability with the ability to mount up to an additional seven side, front, top and bottom fans. The Xigmatek Álfar offers unparalleled value and performance in a mid-tower chassis that will provide years of use and satisfaction.
- Clean aesthetics with an aggressive, eye-catching design.
- Softly leather coating front bezel with orange, white or black iron meshes accents.
- Be able to mount 320mm full-length graphics cards and up to 160mm tall side-blow tower coolers.
- Supports 3 x 5.25” and 4 x 2.5”, 4 x 3.5”devices.
- 2 x USB 3.0 ports with backwards USB 2.0 compatibility.
- HD Audio connectors.
- Pre-installed 120mm silent rear fan and front LED fan, up to 7 additional side, front, top and bottom mounted fans for extreme cooling.
- Bottom mount PSU.
- 7 x PCI slots with thumb screws.
- Dimension: (L) 505 x (H) 445 x (W) 195 mm (19.88*17.52*7.68 inches)
- Drive Bays: 5.25" External x 3 (tool-free retainers) / 3.5" Internal x 4 (tool-free retainers) / 2.5" Internal x 4 (3 tool-free retainers, 1 mount with screws)
- Expansion Slots: 7 slots, tool free PCI slot covers (320mm support)
- Motherboard Support: ATX, MicroATX, Mini-ITX
- Power Supply: Standard P/S2 ATX or EPS
- Front Cooling: Two 120mm fans optional
- Rear Cooling: One 80/120mm fan (120mm orange installed)
- Side Cooling: Two 120/140mm fans optional
- Top Cooling: Two 120/140mm fans optional
- I/O Panel: USB 3.0 x 2 and downward USB 2.0 support by internal 19pin, HD Audio in/out jacks
Only £42.98 inc VAT.
ORDER NOW
Xigmatek Alfar Midi Tower Case - Black/White @ £42.98 inc VAT
- Bottom mount PSU.
ORDER NOW
Xigmatek Alfar Midi Tower Case - Black/Orange @ £42.98 inc VAT
- Bottom mount PSU.
ORDER NOW
- Bottom mount PSU.
ORDER NOW
- Bottom mount PSU.
ORDER NOW
- Bottom mount PSU.
ORDER NOW
