What has happened to my clutch?
29 Dec 2004
Shepley
Driving down the M1 today the bite point of my clutch went from almost instantly from being fine to almost at the floor. Shortly afterwards, the clutch pedal went completely light leaving me unable to select a gear without rev matching. Any ideas? :(
Certainly sounds like a hydraulic issue,
From the description it's likely you have had a slow leak somewhere in the system for a while (seals at either the master or slave cylinder end are most likely but it could be one of the lines or fittings) which has caused gradual fluid loss. You've now lost sufficient fluid that the system has swallowed a lump of air and cannot now transmit effort from the pedal to the clutch.
If this is the case then you should be able to top up the fluid and bleed it to get up and running again, then just keep an eye on the fluid level to make sure it doesn't get too low again. Assuming the leak isn't too bad you can then fix it properly at your convenience.
Of course it's possible you have had a sudden and complete failure in the system in which case you've got no choice but to sort it now.
Expensive fix on a Focus? Slave cylinder sounds right. :(
Sadly yes, the Focus uses a concentric slave cylinder which fits inside the bellhousing, meaning the gearbox has to come out to replace it. It's almost the same amount of work required to fit a new clutch, so it would be wise to budget for a new clutch at the same time unless you know when it was last replaced.
I don't think the clutch was done that long ago but obviously they didn't do the slave cylinder at the same time. :(
Best way to think of these things is, it's something that needed doing sooner or later, it means you've now changed that item and provided the jobs done right shouldn't cause you trouble again.
I'm currently playing coil pack monopoly with my car, it's got to the point that i'm cheesed off with the 1.8T coils so im upgrading to the 2.0T ones, £154 later....
I'm currently playing coil pack monopoly with my car, it's got to the point that i'm cheesed off with the 1.8T coils so i've upgrading to the 2.0T ones, £154 later.....
Yeah, that's the thing I guess.
It's back, I'm £440 lighter but got a full new clutch and cylinder fitted along with a couple of extra bits. Apparently the old clutch didn't look that old - when I bought the car I was told it had been recently replaced - but the muppets obviously didn't do the slave cylinder at the same time to save some money.
Saves me a train fare from London today and back on Monday so I'm happy to have it back and HOPEFULLY it will be trouble free for the next few thousand miles.
