Season 2 has officially ended!
* Eligible summoners will receive loading screen borders, profile banner trims, forum badges, and the Victorious Janna skin immediately
* Summoner Icons will be distributed over the next week
* Elo ratings have been compressed towards 1200 and system confidence in ratings has been reset.
* Placement matches must be completed before Elo will be visible again.
* Ranked stats have been cleared and archived under the "Season 2" option in the dropdown.
Zed, the Master of Shadows
* Pending the completion of some further testing on PBE, Zed will be released at a future date
Brand
* Pyroclasm can no longer bounce more than 5 times.
Elise
* Neurotoxin Ability Power ratio increased to 3% per 100 Ability Power from 2%
* Venomous Bite Ability Power ratio increased to 3% per 100 Ability Power from 2%
* Cocoon
o Missile speed increased to 1450 from 1300
o Now reveals the target if it hits
* Spider Form bonus magic damage per attack Ability Power ratio increased to 0.3 from 0.2
Kassadin
* Nether Blade
o Ability Power ratio increased to 0.3 from 0.15
o Bonus damage no longer hits inhibitors or the Nexus
Katarina
* Bouncing Blade initial damage reduced at later ranks to 60/90/120/150/180 from 60/95/130/165/200
* Sinister Steel damage reduced at later ranks to 40/75/110/145/180 from 40/80/120/160/200
LeBlanc
* Distortion Mana Cost reduced at later ranks to 80/85/90/95/100 from 80/90/100/110/120
Lux
* Final Spark visual effects no longer appear at the wrong angle if aimed beyond the edge of the map
Renekton
* Slice and Dice no longer reduces Dragon's Armor
Soraka
* Infuse tooltip now states the correct Ability Power ratio at 0.6
Twisted Fate
* Pick a Card tooltip now describes the correct behavior in regards to Blue card's Mana restoration
Twitch
* Deadly Venom now has a new particle for maximum stacks
* Ambush tooltip now describes the correct behavior in regards to delay before entering invisibility
Veigar
* Equilibrium Mana Regeneration increased to 1% from 0.75% per 1% Mana missing
Volibear
* Majestic Roar now fears minions and monsters for 3 seconds instead of 2
Xin Zhao
* Crescent Sweep now properly procs Spell Vamp and other effects (e.g. Rylai's slow)
Yorick
* Omen of War now works properly with Life Steal
Ziggs
* Short Fuse now deals 150% damage to structures
Zilean
* Time Bomb now breaks Recall immediately when cast on an enemy champion.
Items
* Blackfire Torch
o New Recipe: Kage's Lucky Pick + Haunting Guise
o Total Gold Cost: 2950 (combine cost: 700)
o +70 Ability Power
o +250 Health
o Unique Passive: +15% Cooldown Reduction
o Unique Passive: +20 Magic Penetration
o Unique Passive: Your spells burn for an additional 5% of the target champion's maximum Health in magic damage over 3 seconds. Each second burned consumes a charge. One charge is generated each second.
o Now available on Twisted Treeline and Crystal Scar.
* Hextech Sweeper
o New Recipe: Amplifying Tome + Amplifying Tome + Kindlegem
o Total Gold Cost: 1920 (combine cost: 200)
o +50 Ability Power
o +300 Health
o Unique Passive: +10% Cooldown Reduction
o Unique Passive: +10% Movement Speed
o Unique Active: A stealth-detecting mist grants vision in the target area for 10 seconds (1 minute cooldown).
* Lord Van Damm's Pillager
o Reduced health by 50
o Reduced armor penetration by 5
* Wooglet's Witchcap
o New Recipe: Needlessly Large Rod + Chain Mail
o Total Gold Cost: 3500 (combine cost: 1200)
o +100 Ability Power
o +50 Armor
o Unique Passive: Increases Ability Power by 25%
o Unique Active: Places your champion into Stasis for 2.5 seconds, rendering you invulnerable and untargetable but unable to take any action (90 second cooldown)
* Removed Zhonya's Hourglass from Twisted Treeline and Crystal Scar
* Removed Rabadon's Deathcap from Crystal Scar
General
* Ignite is now only castable on enemy champions
* Champion passives will now have their cooldowns represented on their passive icon
Co-op vs. AI
* Twisted Treeline bots should now favor defending their base over taking altars.
* Twisted Treeline bots no longer get stuck at the summoning platform when an inhibitor is under attack.
* Custom game Summoner's Rift bots now use the same push logic as beginner Co-op vs. AI bots, which should address several issues of bots getting stuck on the map
* Added a pathing workaround to prevent Summoner's Rift bots from getting trapped in certain areas of the map (e.g. Baron pit)
* Battle Training bots should no longer get stuck during the tutorial
Twisted Treeline
* Reduced Vilemaw's starting damage, increased his starting health, and reduced his health scaling
* Slightly tweaked walkable space in several areas to allow Flashing over walls
* Brush beside altars removed
* Altars now unlock at 3:00 minutes instead of 2:00
* Altars now grant a 3 gold bonus per kill, down from 4
* Minion base gold rewards increased by 1 to compensate
* Jungle monster gold and health values rebalanced
* Removed Thornmail from the purchasable item list
Crystal Scar
* Reduced passive mana regeneration
* Increased mana gained from Health Relics
* Changed windmill rotation speed so gears no longer clip
