Which image type for Intel Gigabit CT PCI-E adapter?
10 Jul 2010
I have a PCI-E Intel Gigabit CT adapter installed in my desktop, and want to upgrade the firmware for it. But which "image type" do I choose when prompted, as I have several choices:-
1) iSCSI
2) PXE
3) EFI
4) EFI + PXE
5) EFI + iSCSI
I'm supposing I should choose option 4 (EFI + PXE) as my motherboard's (Asus P5Q Pro) BIOS is not EFI.
I don't do anything fancy like ethernet booting - I just use it for browsing/gaming/etc. The main reason I chose this adapter was in hope of lower pings/latency when gaming, but I'm not going to argue about that in this current thread! :D
If somebody would go through each option, I'd be grateful. :)
1) iSCSI
2) PXE
3) EFI
4) EFI + PXE
5) EFI + iSCSI
I'll have a stab in the dark:
1) When using it in a SAN
2) When you need ethernet booting
3) I would assume that is an EFI bios for the card rather than if you have it in an EFI BIOS board
4) 2+3
5) 1+3
Personally I'd probably be looking at 2, 3 or 4 in that order.
Because out of date software/firmware is never a good thing for anybody.
Why not upgrade and keep everything up to date?
NIC firmware is a little different. ;)
These things are usually left well alone unless absolutely critical.
