Overclocked bundle wont run Black Ops 2
10 Oct 2009
Hi can someone help please as my son has just got Black Ops 2 and it wont run on his system.
I purchased an Overclocked bundle from OCUK as an Intel Dual Core E5300 @ 3.2ghz / Gigabyte GA-P43-ES3G / Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500c5 DDR2 Bundle.
I appreciate this isn't a great gaming rig, but it should run Black Ops 2? When I look the at system specification it appears to be running as a 2.6Ghz. Black Ops 2 minimum spec is 2.66ghz :(.
The CPU Freq in Bios is showing 2.44 (305x8).
Can someone help me to reset this to the specification that OCUK would have used?
Thanks
ToneDeath4700
There is no error message...it just wont start the application!
The system runs call of duty 3 with no problems.
The minimum, spec for graphics is a Geforce 8800...I thought the 250GTS was much superior to the 8800?
I'm a bit of a noob when it comes to overclocking...if I want to get this back to running as a 3.2Ghz, should I just increase the CPU clock ratio?
Thanks
ToneDeath4700
I only came in here because the "moved" thread still showed in GD.... Some of the posts (like the one above this)... Wow.... Just, wow.... Some people need to get over themselves and get some manners/humility.
A few light hearted comments interspersed with genuine advice, ON NOESS!!! Man. The. ****. Up.
When you say it does not load the game, does the exe file appear in task manager with about 1Mb of memory allocated to it?
If so try plugging a microphone in sounds daft but other CoD games have had this problem.
Kimbie
Guys, thanks for the advice and i will check the nvidia drivers etc.
Can someone help me with the question on the overclocking?
Its possibly just idle clocks, try running prime95 and see what its running at in a program called cpu-z , you need to find this our before tweaking clock settings
