corsair vengeance 1500
25 Nov 2011
The KOP
Anyone have theses? What's you option on theses headset. I in market for new Headset willing to spend £70 This the Price I can get theses corsair vengeance 1500 for.
Is they anything better for that price?
I want it to be USB so if you have a better set make sure its USB :)
Thanks
I bought a pair in February and they're very good. The build quality is top-notch, the ear-pads are comfy memory foam and the sound quality from the earpieces are excellent.
The only negative point is that they're not great for music; they lack bass, although you can improve this by using the headset equaliser settings.
I can easily recommend them.
I bought a pair about 2 weeks ago now and love them. As you say though, they do lack bass but this is easily solved by using the equaliser.
I would defiantly recommend them.
Not sure I think the base is very good on Dolby setting with FPS EQ. Playing BF3 before WoW all the explosions were special. The sound is that good It was like playing a new game :)
