think of microwave wattage as our MHz/GHz. moar power = faster nuking![]()
What you could do is make a microwave that worked at a lower frequency. More power would be delivered to the food because free-space path loss is reduced at lower frequencies.
Don't eat microwaved food people, it's full of radiation!!!
You'll probably come back with, actually it would need to be milliwave or something![]()
I think some work at 915 MHz. Big industrial units. However free space path loss over not-a-lot-of-distance is not going to be a terribly large amount and the resonators in the magnetron would need to be bigger and probably heavier. Need moar powar.
Yep. All valid points. The easiest way is just to pump more power into the thing.
I'm amazed that 750w and there abouts still seems to be the norm. I've had a 1000w microwave since 1999 or so, but you hardly ever see them in shops (and no microwavable food has instructions for a 1000watter). Is there a reason they don't sell 1200/1500/2000w+ machines?
They have two of everything in there
Probably a price thing - all commercial microwaves are much higher than domestic. Infact if you open a commercial microwave up, you can see its basically two domestic microwaves in oneThey have two of everything in there
It is radiation but there again so is visible light.
The idea that water resonates at this frequency is a common misconception. What actually happens is a process called dielectric heating. Polar molecules have an electric dipole moment and align themselves with the electric field. RF is just high frequency AC, so as the electric field oscillates these polar molecules rotate back and forth to keep in line with the field. Some other things in foods, such as fats and sugars, contain polar molecules as well. These are less polar than water molecules but are still subject to the same effect, albeit to a lesser extent.Water resonates at the frequencies involved, so it absorbs the energy willfully and with speed, thus cooking water rich items works well in a microwave oven.
We had a whacking great big Toshiba 1000w machine from the 90's, it only gave up the ghost a few years back, never found anything that stacks up to it since, the new ones seem like toys compared to that behemoth, you could fit a modern microwave oven inside that big old hulking brute.
I miss that damned thing.
