Call of Duty: Black Ops II
Every other cod get away with it, what happens on here if both teams have a flag , both teams start spawning ontop of each other making it chaotic, it will spawn you right next to the enemy you spawn turn around and you have 3 of the enemy spawn behind you
Tesco had loads of copies of the game but no points. Luckily I spotted the trolley full being wheeled out and the man found a random 2100 points amongst the games
COD has always tended to spawn you at A or C depending on if your team holds one of those flags, if not then you can spawn either way I guess depending on where your other team mates are.
Only solution is a dedicated spawn area which just opens up a whole other can of worms when you find yourself spawn camped :)
An adaptor that lets you use a keyboard and mouse instead of a controller on 360/PS3. A lot of people here frown upon it's use in FPS games as they feel it is tantamount to cheating. Most people don't really care, but it always leads to accusations of cheating when someone mentions they are using one!
rp2000
I think it's cheating as well. You get a massive advantage over people playing with a control pad. Mouse & Keyboard shouldn't be allowed on a console.
Is it just me or is everyone drop shotting on this? Jumping around corners and drop shotting
I have crouch set as click-right-stick and sometimes accidentally dropshot. I'm so pro :p
Tried the Vector out earlier and it's actually awesome.
Finish early. Get home quickly. Prepare snacks. Intend to get a CoD session in before the other half is over and before the football tonight... Servers are down :mad:
(xbox)
OK came this morning. (Got compensation for it being late, works out at the game for £30, not bad).
Aside from spawning being utterly broken its not half bad, certainly better than MW3. Lag compensation is still not right but no worse than MW3.
I expect the MP7 to be nerfed quite a bit. Though balancing in any game is never right no matter how much you fiddle with it.
No different to saying a person whos bought a steering wheel and pedal box to play on forza 4 has an advantage over someone using a controller.
If its cheating then MS would have banned it. (but i guess theres tehcnically no way to ban it?)
