- 25 Nov 2011
- The KOP
Edit Sorry can a MOD move this to Testing section.
Hello I got my sig removed from admin and I would like to know what for.
From FAQ
You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted.
My sig has only 4 lines?? and its also set to the smallest possible.
Looking for general advice
Thanks
From FAQ
Thanks
