- 25 Nov 2008
I have been looking at http://www.coolermaster.outervision.com/index.jsp, and it comes up with 390W
What do you mean exactly?
Your PSU is a cheap budget item, thus unlikely to ever put out its rated power and is a liability.
Such as,
http://www.tomshardware.com/reviews/low-cost-psu-pc-power-supply,2862.html
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=123
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=154
I have a budget of £374, and that has to include delivery I can not afford a single penny more.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £184.99
1 x Corsair Builder Series CX 600W V2 '80 Plus Bronze' Power Supply (CP-9020048-UK) £56.99
1 x **B Grade** Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 (MB-364-GI) £35
1 x Thermalright HR-02 Macho CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) £33.59
1 x Avexir MPower Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (AVD3U16000904G-2CM) £29.99
Total : £352.56 (includes shipping : £10.00).
Do you know if the http://www.overclockers.co.uk/showproduct.php?prodid=BG-252-GI will my support my GPU ? Point of View GeForce GTX 260 896MB GDDR3 TV-OutDual DVI
(PCI-Express) - Retail
You can afford all new parts,
YOUR BASKET
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £89.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £43.99
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £29.99
Total : £360.96 (includes shipping : £10.00).
The Z77 will allow you to overclock the chip fully.
The Z68 doesnt have a full UEFI and thus will be stuck at a maximum of 38X (giving you 3.8GHz) unless there is a UEFI BIOS (had a quick look and cant see one) that you can do to make the switch over from Award to AMI.
Like so - http://forums.overclockers.co.uk/showthread.php?t=18404556
Retail CPU's include a stock cooler with thermal paste all ready applied.
OEM are just the chip in a plain box and a one year warranty (retail is 3yrs).
Looks like it can.
I assume theres a nice space under your existing board and some PCI rear slots that look like they cant currently be used ads they dont line up with anything currently?
well sounds like an ATX will fit fine and that will then line up with the extra slots, but if you are unsure - http://www.overclockers.co.uk/showproduct.php?prodid=MB-394-GI&groupid=701&catid=5&subcat=2261
Also worth remembering you can DSR the ATX board back to OcUK if for some outer space cosmic reason it doesn't fit.
