E46 Control arm + Bushes
Caporegime
28 Jan 2003
England
So I need to replace both front arms and bushes on my E46 does this kit:
This kit come complete with everything I would need?
It appears to and being a set I would assume it is.
Christ that's cheaper than control arms for my wifes focus. so much for premium german cars costing a fortune to run :)
That's still a good £400+ after labour (cheaper if you can do it yourself) plus allignment on top for a set of control arms, its hardly cheap is it (Well, its cheap for what it is, but it's not 'wow, this is so cheap to run'.
Had this done on mine recently too, if yours are on the way out then you will definitley notice the difference.
I got mine off ebay for £200 though. Labour cost me £160.
It is but I do not have the tools/knowledge or inclination to do it myself.
no, my point was that id expect it to all go ahead smoothly ie very little to go wrong with something like that
for a set of crucial parts which need replacing so infrequently and being replaced with meyle bits, i think its a really cheap fix, youll feel the difference
just need to think about the rear now unfortunately
