Hi all
Long time lurker here - have been reading and following the forums for a while.
I have been using a Zalman reserator V1.2 for a while - currently it's just cooling the CPU and it is nice and easy to maintain and setup but now I am contemplating the jump to a "proper" watercooling setup - mainly due to the fact that I now have 2 GTX680s situated right next to each other and they tend to get a bit toasty after a couple of hours of Crysis
So, looking for a bit of advice. I have read most of the guides and looked at the various options and I am thinking about the following as a solution for cooling both GPUs and the CPU.
1 x XSPC RayStorm 750 RS240 kit
1 x 240 RAD
2 x Full cover GPU blocks
So a loop with 2 240 rads - imagine the sequence would be:
reservoir/pump > CPU > rad > GPU > GPU > rad > reservoir/pump
CPU is a Bloomfield 930 running at stock currently. Not currently interested in OC but depends on the temps I get if I take the plunge.
Does this sound sane at all?
1 x 240 RAD
